Concours Owners GroupTM - COG
"Sport touring at its fines
t SM"
Concours Through Time
Join for the Bike,
Stay for the PeopleSM
   Forum           Events
Forum - Legacy Please see the NEW Forum / Concours C10 / ZG1000 General Chat and Tech / Gear Oil Leak at Rubber Boot
Home   Login Join Search
moderated by norm9688  Reply to Discussion | New Discussion | Subscribe << previous || next >>
Posted By Discussion Topic: Gear Oil Leak at Rubber Boot
 subscribe to  this topic Printer-friendly Version  new posts last
Marrsman
03/16/2010 @ 7:18 PM
reply
profile
send p.m.
Tricycle
Hey All,
I have a 2000 with 33k on it.  There has always been a slow leak of gear oil at the rubber boot that protects the drive axle pinnion and connects to the rear swing arm.  Correct me if I am wrong, but examining the Clymer manual, it looks like the swing arm is dry (no gear oil).  So the leak should be occuring with one (or both) of the o-rings on then end of the drive shaft.  Am I correct?  Through reading the other forums, over filling is a problem that cases leaks.  Could over filling cause the leak at the boot, not just at the final gearcase?  I filled slightly passed the fill hole (not knowing any better), last time I changed the rear end oil.  I have not had any problems with the large oil seal in the final gearcase, and have never had to take the swing arm apart.  My hypothesis is that is traveling through the swing arm to the boot.  I am pretty sure that the leakage at the boot is gear oil, as it smells like it (rotten meat).  The leak is not a huge deal, but I am taking a 9000 mile trip and want to resolve the issue before leaving.
Am I on the right path?  Any one else deal with this?  Any ideas an input is always appreciated.  I am trying to do research before I tear into the bike to reduce headaches.  Also, is there a special material that the O-ring has to be, or will any do?
Thanks All!
http://i950.photobucket.com/albums/ad348/djmarrs_bucket/VisitedProvincesMap2-1.jpg?t=1264819451
davidsturgis
03/16/2010 @ 7:26 PM
reply
profile
send p.m.
Road Bike
Do you think it could be moly grease that has s eeparated? I know that the driveshaft spline area is usually filled with 2 ounces of grease (I think) and maybe it's running down to the junction and weeping out.
Do you notice any oil loss in the rear end? If it's noticeable you may see levels drop over several thousand miles.
David
David in Jax COG# 7898
NE FL AAD & COG
Vendor www.dreamjobresumes.com preparing resumes for COG members and friends
I ride a KAWASAKI ZZR1200 -
Euro http://www.motorbikestoday.com/reviews/Articles/ZZR1200.htm
US http://www.motorcyclistonline.com/roadtests/2002_kawasaki_zzr1200/index.html
Marrsman
03/16/2010 @ 7:52 PM
reply
profile
send p.m.
Tricycle
There hasn't been any noticable loss in rear end fluid.  It stays pretty consistant.  The seepage has covered the oil pressure sending unit, center stand, and side stand with a thin coat of oil that attracks sand/dirt.  Not a bad hypothesis.  I should take it apart and re-grease it.
U.S.
colinp386
03/16/2010 @ 8:06 PM
reply
profile
send p.m.
Administrator
If you are seeing oil on the boot, its more likely that it is coming from:
A) The breather union from the top of the crankcase to the bottom of airbox
B) The Bevel Drive Gasket (this is hard to diagnose
C) The Gear Shift Seal.
Try removing the lower fairing clean the whole area up with a good degreaser then take it for a short 10 mile or so run.
A leak is then easier to find easpecially if you dust on some talc or foot powder. My guess would be the Bevel Gear Gasket, for a while they made them of paper and the rear edge blows out. The newer gaskets went back to metal and are much better.
CP
Colin Prior
COG IT Officer
Lake Forest Park WA
COG#7767
AMA#1081764
ROK#20000617
Marrsman
03/16/2010 @ 9:35 PM
reply
profile
send p.m.
Tricycle
Thanks for the starting points.  I checked the breather union and it was bone dry.  The bevel gear gasket is a metal one and also looks dry.  I was able to pull the boot forward and the bevel seal looks dry.  The swing arm, however looks like there has been oil traveling up it, though leaks are weird like that.
I will take your advice.
Thanks!
U.S.
Marrsman
03/20/2010 @ 7:11 PM
reply
profile
send p.m.
Tricycle
Hey All,
The final diagnoses is the front seal is leaking.  I brought to Cycle City in Rochester, MN and had a tech look at it.  He quickly pulled the boot and used some mirrors.  The fluid is traveling the length of the swing arm.  DO NOT OVER FILL THE REAR END.  Lesson learned.  I having the shop do the work on this one.  They are also changing all hyrdolic fluids, coolant, and a valve job.  I could it all, but am sick of wrenching on it.  I farkled the hell out of it two weeks ago.
Thanks all for the comments.  I have always been humbled by the knowledge that people in this group have.:)
Photobucket
Daniel Marrs
Red Wing, MN
COG #9027
colinp386
03/20/2010 @ 9:18 PM
reply
profile
send p.m.
Administrator
Glad you got it fixed!
Many folks overfill the rear diff, most of the time it tends to splatter over the rear wheel which aint much fun!
Colin
Colin Prior
COG IT Officer
Lake Forest Park WA
COG#7767
AMA#1081764
ROK#20000617
This Forum has Been Replaced
New Forum at http://forum.cog- online.org
Forum - Legacy Please see the NEW Forum Home
Membership
   Join Now
   Renew Membership
   Membership Benefits
   Membership FAQs
   Industry Members
   Forum Subscriber Only
   Contact COG
COGMOS Features
   Calendar of Activities
   National Rally
   Common Questions
   Forum
   COG Links
   COG Member Store
Social & Community
    COG Forum
    Facebook
    Twitter: COGRiders
Join COG
Renew Now
Forum
Contact COG
COGMOS Version 1.1 © 1989-2016 Concours Owners Group™, All rights reserved.    Privacy Policy  | Terms of Use  | Contact Us
Bookmark and Share
Membership Management by Memberize™
© 2001-2018 Hill Country Technologies, LLC. All rights reserved.
Your session is about to expire...
Login Required
Admin Order Form
