Concours Owners GroupTM - COG
"Sport touring at its fines
t SM"
Concours Through Time
Join for the Bike,
Stay for the PeopleSM
   Forum           Events
Forum - Legacy Please see the NEW Forum / Concours C10 / ZG1000 General Chat and Tech / Spitting Oil
Home   Login Join Search
moderated by norm9688  Reply to Discussion | New Discussion | Subscribe << previous || next >>
Posted By Discussion Topic: Spitting Oil -- page: 1 2
 subscribe to  this topic Printer-friendly Version  new posts last
Kurt_Lammon_TN
02/10/2010 @ 8:12 AM
reply
profile
send p.m.
Tricycle
I got my '01 on Labor Day last year and I'm still getting used to it. When I picked it up, the guy who'd owned it previously had the oil filled up beyond the top of the sight glass. On my ride back home, after getting a bite to eat at an Arby's, a Gold Wing rider who saw the small puddle of oil under my bike said "those bikes will spit oil out of the breather if you overfill them."
When I got back home, I drained the excess oil out and now the level's 3/4s up the glass. I've cleaned the oil out of the bottom plastic cowling a couple of times, but it's still leaving its mark several months later (although seems to be less now than in the past).
Question: does it take a long time for the oil to clear itself out from the breather? (And where is this breather?) Or do I have a bona fide leak from a gasket or something?
My next step if you guys don't tell me something revelatory will be to change the oil and replace the gaskets on the drain plug and filter. Let me know if anybody's got experience with this. Because of the overfill situation, I'm still suspecting the breather.
Thanks!!
Kurt Lammon
Chattanooga, TN
www.urethanesupply.com
Kurt Lammon
Chattanooga, TN
2001 Kawasaki Concours (current)
1979 KZ650, 1982 Honda XR200 (long-gone)
http://www.urethanesupply.com
davidsturgis
02/10/2010 @ 8:36 AM
reply
profile
send p.m.
Road Bike
Kurt,
The stock oil filter is foam and absorbs oil. I once washed and oiled mine and used too much oil and it dripped some oil. You may want to remove the air cleaner (left side, a couple of screws I think) and wring the oil out of it. Wipe down the inside of the air box and that should take care of it.
David
David in Jax COG# 7898
NE FL AAD & COG
Vendor www.dreamjobresumes.com preparing resumes for COG members and friends
I ride a KAWASAKI ZZR1200 -
Euro http://www.motorbikestoday.com/reviews/Articles/ZZR1200.htm
US http://www.motorcyclistonline.com/roadtests/2002_kawasaki_zzr1200/index.html
sawfiler
02/10/2010 @ 9:13 AM
reply
profile
send p.m.
Street Cruiser
"The stock oil filter is foam and absorbs oil"
I think David meant air filter not oil filter.  The stock oil filter is paper and sealed inside the oil filter housing.
The air filter could could possibly be over oiled though.
"If it hasn't killed me yet, it's runnin out of time"
COG # 8062
AMA # 1084053
ROMA or Scarlet harlot acording to my wife
davidsturgis
02/10/2010 @ 9:36 AM
reply
profile
send p.m.
Road Bike
Oops!
Good catch - I meant to say "air filter"
The form air filter will absorb oil that blows out the breather and then it will drip and weep forever unless you clean it out. It's not a big job and only requires you to remove the left side cover and one or two screws for the end cap.
Good luck with it!
David
NE FL AAD & COG
colinp386
02/10/2010 @ 9:59 AM
reply
profile
send p.m.
Administrator
Kurt;
The breather connection from the crankcase to the airbox is on the LHS top of the crankcase. Its a small black plastic elbow that connects directly into the bottom of the airbox.
Don't get fixated on it being all about overfilling the engine, it may not be that at all. There are other places a connie will leak oil.
After cleaning out the airbox and checking that the breather is connected to the airbox if its still leaking take a look at.
Drain Plugs x 2
Oil filter O-rings x2
Gear Shift Seal
Clutch rod seal
Water Pump Seal
All those are on the LHS.
Last but not least is the Bevel Drive Gasket
which is the most difficult to check and hardest to replace.
Colin Prior
COG IT Officer
Lake Forest Park WA
COG#7767
AMA#1081764
ROK#20000617
Kurt_Lammon_TN
02/15/2010 @ 6:37 PM
reply
profile
send p.m.
Tricycle
Great info, guys. This forum is awesome! I really appreciate the help. I'll check the air filter very soon and probably go ahead and replace the oil with Mobil 1 and the filter with all gaskets and o-rings.
Thanks,
Kurt Lammon
Chattanooga, TN
timgaskell
02/19/2010 @ 6:42 PM
reply
profile
send p.m.
Big Wheels
Hey Guys - I am going nuts with an oil leak on my '99.  I replaced the o-ring on the waterpump, and thought I had it after seeing no problem on a quick 10 mile test.  But, riding to work, it started smoking from oil on the left eshaust, and puddled at work.  I just dropped the belly pan, and there is fresh oil in it too.  I changed the oil and filter during the o-ring job.  The left side of the engine is wet up to the clutch slave or so.  I just wiped it down, and laid under it and watched while it ran for a couple minutes - nothing!  It is upright on the centerstand.  I had the clutch slave out so I could watch it too.  Does a particular area leak mainly only during riding (from leaning, etc), or when warmed up, or???
TIA for any thoughts.  I go nuts when I can't ride, a common affliction in this group, huh.
Tim
The CFO
02/20/2010 @ 12:24 AM
reply
profile
send p.m.
Big Wheels
Tim the O'ring on the Oil pump is not the culprit when the water pump leaks oil!
It's the Oil Seal that sits on the shaft.
Colin
(Using the CFO's account)
davidsturgis
02/20/2010 @ 7:19 AM
reply
profile
send p.m.
Road Bike
Mine smoked a little bit on the left side, mainly when I was stopped at traffic lights, because oil was slowly dripping out the weep hole on the water pump. The bearing inside was going bad slowly and the extra clearance allowed the shaft to move enough so that oil could get past the seal and drip out the weep hole. Mine did not leak a lot but I could see and smell it, as time goes on it would have gotten worse. I got a pump from Murph and replaced the whole thing.
Maybe this is the problem?
David
NE FL AAD & COG
timgaskell
02/21/2010 @ 5:08 PM
reply
profile
send p.m.
Big Wheels
Thanks for the comments, Colin & David.  I've concluded the most likely cause is the clutch push rod seal.  It falls out of the opening, and is loose on the rod.  I think it is ready for replacement after 60,000 miles in the Southern Cal heat.
My problem now is trying to find it on a microfiche.  Ron Ayers and Kawasaki parts house.com both use the same OEM microfiche, and I just don't see it on the clutch page.  The seal is marked "ARS S0 48 8 18 7-1", an Arai SO type seal, but I can't find it anywhere.  I just emailed Ron Ayers regarding it, I'm sure they will straighten me out.
Any other info would be most appreciated, though.  A couple more weeks of downtime, I guess - I know that sounds minor to the good folks in the great white north, but here it's a pain.
Tim
PAGE: 1 2
This Forum has Been Replaced
New Forum at http://forum.cog- online.org
Forum - Legacy Please see the NEW Forum Home
Membership
   Join Now
   Renew Membership
   Membership Benefits
   Membership FAQs
   Industry Members
   Forum Subscriber Only
   Contact COG
COGMOS Features
   Calendar of Activities
   National Rally
   Common Questions
   Forum
   COG Links
   COG Member Store
Social & Community
    COG Forum
    Facebook
    Twitter: COGRiders
Join COG
Renew Now
Forum
Contact COG
COGMOS Version 1.1 © 1989-2016 Concours Owners Group™, All rights reserved.    Privacy Policy  | Terms of Use  | Contact Us
Bookmark and Share
Membership Management by Memberize™
© 2001-2018 Hill Country Technologies, LLC. All rights reserved.
Your session is about to expire...
Login Required
Admin Order Form
